5.3 Heads or tune
Old 03-06-2008, 06:52 PM
fattony's Avatar
Default 5.3 Heads or tune
Ok so Im in a delima of what should I do I have a car that should be tuned but any way here are the mods
Tsp T2 cam 232 234
241 stock heads
Dual timing chain
Lingfelter (cantspell) oil pump
SVO 30lbs injectors
BBK SSI intake with 80mm TB
Long Tube 1 3/4
2 1/2 xpipe through exhaust
not installed
Patriot Springs Kit good for .650 lift
Patriot Shaft mounted roller rockers 1.7
So here is my Q
I have $2000 to splerge on mods should I
1 Get TSP 5.3 stage 2.5 Heads and bump compression to11.1 and have a few bucks left over for what ever?
2 Get HP tuners, wideband, and get what I have so far and good tune?
3 Car is good enough and save up for...(insert something)
Please give me any suggestions you feel neccessary This will probably be my daily car but at the same time track *****
I have searched and found nothing in regards to this but I posted my recient dyno an it has aft readings check out my other post
Thanks
Tony
Old 03-06-2008, 07:05 PM
getusumws6's Avatar
heads and tune, you want heads and need tune,and still have enough for wideband
Old 03-06-2008, 07:14 PM
Gun5's Avatar
just get a good dyno tune don't need a wideband then
Old 03-06-2008, 07:21 PM
fattony's Avatar
really and should I get the Pro or the regular HP Tuner?
Old 03-06-2008, 08:35 PM
RedRallyeZ's Avatar
im with gun, get a dyno tune. less money and most shops have a return policy where whenever your tune needs an update it can be as little as $20. post in your regional forum and find a good gen III shop that can help you out
Old 03-06-2008, 09:05 PM
rsodeputy61's Avatar
sounds to me like the perfect time for a 12 bolt...
