victor jr
Old 03-09-2008, 08:08 PM
teddyls1's Avatar
Default victor jr
I did a search and didnt find a answer to the question will the victor jr fit under the stock hood if not what hoods will work. Also any pictures would help cause I would like to see how much of the cowl you have to cut. Thanks!
Old 03-09-2008, 08:15 PM
WFOSS's Avatar
I am in the process of installing mine right now. I have an SS hood and had to cut a section of it out to make the hood clear (don't have the cash for another hood right now). So to answer your question, no the stock hood will not fit. I will post up pics as soon as I get some.
Old 03-09-2008, 08:33 PM
ssfast99's Avatar
I Had To Cut My Stock Ss Hood Also, So I Decided To Cut More And Put A Carb Nitrous Plate On And It Looks Bad ***. I Used The Intakeelbow Setup And It Almost Cleared Without The Plate. I Think It Will With The Low Profial Elbow That A Sponsor Has On Here.
Old 03-11-2008, 10:41 PM
teddyls1's Avatar
any input on what hood will work with out cutting
Old 03-11-2008, 11:00 PM
massls1guy's Avatar
Search in Gen III external engine section:
https://ls1tech.com/forums/generation-iii-external-engine/836671-edelbrock-intake-design-torque.html
Old 03-11-2008, 11:03 PM
teddyls1's Avatar
thanks
Old 03-12-2008, 09:30 AM
NOZR1's Avatar
I have the Vic Jr. with the elbow from Nitro Dave's and it fits under the stock hood fine with no cutting. I didn't have to notch the cowl, but I did just in case. It was easier to do it since I had the motor out and you can't tell since I put the factory rubber strip across the cowl back on.
