Need help guys
Old 03-11-2008, 10:53 PM
817Borla's Avatar
Default Need help guys
i have a 99 stock LS1 T/A i wanted to put a cam and heads on it. any advice as which type, brand i should get?? and do i need to install anything else before put the the cam and heads in?
Thanks
Old 03-11-2008, 11:11 PM
headed-ws6's Avatar
what kind of budget are you working with? What size cam do you want? do you have the supporting mods like headers duels/y-pipe?
Old 03-11-2008, 11:26 PM
817Borla's Avatar
everything is stock all i have is a borla catback. as for budget around 2500. for the size thats where i need help i dont really know much about cams i appreciate all the help i can get
Old 03-11-2008, 11:37 PM
discostu's Avatar
first thing first is it an m6 or a4
Spieldawg's Avatar
your gonna want LT's at least....
Old 03-11-2008, 11:42 PM
headed-ws6's Avatar
yeah get a set of LT and a y-pipe first and a ls6 intake and and ported throttle body
Old 03-11-2008, 11:58 PM
BayAreaSS's Avatar
I would use that money for bolt ons first. You need LT's/y-pipe, Ls6 intake, lid, ported tb and then you can get the heads a cam
Old 03-12-2008, 12:06 AM
LS1Silverado05's Avatar
The cam will only work as well as you let it. I agree with the guys above. I say Longtubes/ ORY and LS6 minimum.
Old 03-12-2008, 10:14 AM
SOMbitch's Avatar
Agree with above except the ported TB is more of a throttle respone mod than HP mod. If your A4 you gotta throw a stall in there first too. Think Yank!!
Old 03-12-2008, 10:19 AM
Z Fury's Avatar
I agree with the above. You have to provide the air flow for the new heads/cam to function better. Not to say that heads/cam is a bad first mod, you just won't be using them to their full potential until you knock out the basic bolt-ons first.
Also, is $2500 your entire budget, as in parts + install? Install won't be cheap, as you'll need a tune after a heads/cam install.
Old 03-12-2008, 09:28 PM
817Borla's Avatar
the car is an A4. Thanks for all the help guys
Are QTP Headers good?
Old 03-12-2008, 10:34 PM
817Borla's Avatar
T.t.t
Old 03-13-2008, 12:23 AM
BayAreaSS's Avatar
Yes they are good but if you're on a budget i would get Pacesetters
