Cam profile?? Can anyone help...
Old 03-11-2008, 11:35 PM
Spieldawg's Avatar
Default Cam profile?? Can anyone help...
I took my cam in to get profiled, becuase I wasn't really happy with the cam card sent with it, written in ink, on a 5 x 7 note card.
The Specs I was quoted was 218/228 550/550 on a 114 LSA.
According to this IF i am reading it right, the specs are 234/226 546/552 on a 114 LSA????
So here are the specs
LIFT Dur. Open Close Area
Lobe intake 1
Centerline 118.6 BTDC 0.006 293.9 78.7 BBDC 35.2 ATDC 26.48
0.050 Lift C/L 116.8 BTDC 0.020 264.6 67.6 BBDC 17.0 ATDC 26.29
RUNOUT 0.0025 0.050 234 53.7 BBDC .2 ATDC 25.74
PEAK OPEN ACC 0.000325 0.100 201.1 38.3 BBDC 17.2 BTDC 24.48
PEAK NOSE ACC -0.000285 0.150 173.5 24.9 BBDC 31.4 BTDC 22.71
PEAK CLOSE ACC 0.000305 0.200 144.9 11.1 BBDC 46.1 BTDC 20.35
LIFT @ TDC 0.0506 0.250 110.7 6.1 ABDC 563.2 BTDC 16.23
MINIMUM FLAT 0.300 61.3 30.5 ABDC 88.2 BTDC 9.63
FOLLOWER DIA 0.8639 0.321 --- PEAK CAM LIFT ----
0.546 --- PEAK VALVE LIFT ---
Lobe EXHAUST 1
Centerline 110.6 ATDC 0.006 268.8 30.6 BTDC 72.6 ABDC 25.76
0.050 Lift C/L 111.4 ATDC 0.020 257.6 17.0 BTDC 60.6 ABDC 25.57
RUNOUT 0.0019 0.050 226.8 2.0 BTDC 44.8 ABDC 25.07
PEAK OPEN ACC 0.000315 0.100 194.2 14.0 ATDC 28.2 ABDC 23.77
PEAK NOSE ACC -0.000276 0.150 167.4 27.2 ATDC 14.6 ABDC 22.04
PEAK CLOSE ACC 0.000295 0.200 139.9 40.7 ATDC 0.7 ABDC 19.79
LIFT @ TDC 0.0553 0.250 107.9 56.6 ATDC 15.5 BBDC 15.92
MINIMUM FLAT 0.300 61.9 79.5 ATDC 38.6 BBDC 9.8
FOLLOWER DIA 0.8752 0.3246 --- PEAK CAM LIFT ---
0.552 --- PEAK VALVE LIFT ---
114 LSA
114.5 CL
If its too hard to read, I have this in word format attached.
File Type: doc
Old 03-12-2008, 01:30 AM
CNB
CNB's Avatar
That's what it looks like according to your word doc. That is a big discrepincey between what you ordered and what you received.
Old 03-12-2008, 01:35 AM
Spieldawg's Avatar
THANK you for responding.
So what do you think it would perform like. Its ALOT different than the hot cam... but its about the lift I was looking for... Reverse splits can produce decent power...
Old 03-12-2008, 06:03 PM
Spieldawg's Avatar
anyone?
Old 03-12-2008, 07:15 PM
FMX05's Avatar
Unless you have a really good exhaust and possibly ported/aftermarket heads the discrepancy in your exhaust duration could hurt your numbers. Only one way to find out... lol
Old 03-12-2008, 11:42 PM
Spieldawg's Avatar
I am running 1 3/4 long tubes no cats and a flow master exhaust. I have a LS6 Intake and a New Era CAI through a stock TB... You guys think 370-380 rwhp is realistic?
