Custom Grind Specs....
Old 07-21-2003, 11:03 PM
Nagash01WS6's Avatar
Default Custom Grind Specs....
Well.. I think I know what Im going to go with on my custom grind... 232/236 .585/.585 113LSA on an XE-R lobe. Im hoping for the 380 to 390 range on this cam.
What do you guys think?
Old 07-22-2003, 12:54 PM
Constrictor 98TA's Avatar
Default Re: Custom Grind Specs....
Well, that cant be on XE-R lobes. If they were, your peak lift would be .595/.602.
Going up from a Hotcam, you will definitely need some tuning to get that to work in an A4. The G5X2 cam has similar specs and is seeing some pretty good numbers, even with stock heads. I think you may be able to hit 400 with that cam.
Old 07-22-2003, 01:04 PM
Vents's Avatar
you talked to mark at comp didnt you ;D he ground a similar cam for me a little while back. i see you plan on spraying it? it will definately make for a great nitrous cam, but wont be all the great n/a. i setup my motor to run on the jug though. sounds like a good pick, you shouldnt have a problem w/ ~400 or so.
