Pred Z ? about 224/224 .568/.568 110+4
Old 03-12-2008, 09:33 AM
Indiana Hawk's Avatar
Default Pred Z ? about 224/224 .568/.568 110+4
Seen your posts in a thread back in '05 about this cam. What are the street manners like on this cam? I'm guessing it's pretty rough? I like the 380rwtq at 3000 rpm. This is the kind of torque curve i'm looking for--alot down low.
https://ls1tech.com/forums/showthrea...=402326&page=2
How would the above cam match up against the one you suggested here-
https://ls1tech.com/forums/generation-iii-internal-engine/869124-224r-vs-tr224.html
Old 03-12-2008, 09:43 AM
PREDATOR-Z's Avatar
The 110+4 is a very peaky cam, does exactly as seen in that thread, low rever and massive trq lo>mid range.
Since 2005 the XFI lobes came into play and the 224/224 111+3 XFI/XE-R cam will have similar output as the XE/XE 110+4 but will carry a bit further in the rpms
The XFI/XE-R should make another 10/15 rwhp extra properly setup.
I have no doupt that in a M6 + bolt ons + (LS6 intake and healthy motor) that the 224/224 XFI/XE-R will make at leat 400 rwhp and equal mount of trq
If I would set it up, I could do the same in a A4 (I've done it here for a guy with 01 z28)
Old 03-12-2008, 10:40 AM
What will the lope be like on either of these cams? Will it be tolerable on the street or are these cams more for the strip? My relative tolerance level for lope would be anything similar to a tr224. Are these both custom ground cams or is there a sponser that stocks them?
Old 03-12-2008, 11:21 AM
blown03mustang's Avatar
thats exactly what im lookin for! i want a mid range cam w/ a lot of torque! how does it handle on the street and where can i get one?
Old 03-12-2008, 11:43 AM
slt200mph's Avatar
You might want consider going to 224/228 .581/.588 110+0 and make more HP and TQ..great street cam good lope and peaks @ 6300 rpms .. comp cams will grind you one .. good street manners you can put it in 6th gear @ 55 mph and it will drive like it is stock ... you will need a good tune to make any cam work ..
Old 03-12-2008, 12:57 PM
Is the more power from the 224/228 going to be up high or down low? You got any video or dyno graphs of this cam?
Old 03-12-2008, 03:03 PM
slt200mph's Avatar
The motor make plenty of power low, mid, and up top..peaks at 6300 rpms...I moved a couple of months ago and I'm not sure where the dyno sheet is these days..I'll have to see if I can find it and post it up for you...I have a very good set of TEA 5.3 heads milled down to 54cc and use the .040 Cometic head gaskets for a good quench ... I am more than happy about the way the car performs..I ran a much larger cam for 45,000 miles before I went to this grind... I prefer this one.
Old 03-12-2008, 08:59 PM
fuzzyjk's Avatar
Who makes the cam and is it a smooth or rough running? Where is the powerband on this cam is there enough down low or is it slugish until the rpm's grow.
Old 03-12-2008, 09:59 PM
hammertime's Avatar
A 224 cam on a 110 ICL has an Intake Valve Closing Point at 42 degrees, and should peak around 6100 - 6200. Adding four degrees exhaust duration increases the overlap two degrees (at the same LSA) so the idle would be just a bit dirtier, and the potential to carry the top end a little higher.
The more you advance the cam, the stronger the torque in the low revs, but you do trade power up top. The VE's look better IMO if you use the next smaller lobe and less advance.
Old 03-13-2008, 01:19 PM
slt200mph's Avatar
LIke I said it peaks at 6300 and pulls like a freight train...great bottom, mid and top....and you do not have to wind it up to 7000 to make good power.
