Either plug will work ... you just have to read your plugs and see which one looks better...generally if you raise your compression the TR6 will be better...with stock compression the TR55 is the usual choice...
if you plan on spraying it I would run tr6's. I use those and I love them, if your going motor I have heard from alot of people that tr55's are the way to go
