My new build!!
My new build!!
I just recently found metal from a rod bearing in my oil after 104k miles so i decided to go another route. I finally have all the parts ordered now to finish it. I'm going with an LQ4 shortblock with new rings and bearings,arp rod bolts,LS2 timing chain and oil pump,.040 cometic head gaskets,243 heads milled to 62cc,Patriot Gold springs,MTI X1 cam,LS7 lifters,TEA ported weiand intake,and pacesetters and ory. Also i'm doing an M6 swap at the same time and using a LS7 clutch. What does everyone think about the combo and what kinda power should it make? I plan on it running in 3 weeks!
That sounds like a very stout combo i would say if the heads arem't ported then i'd say 410rwhp. put if they were ported depending on how far anywhere from 430+. Either way will have some good low end torgue with that X1.
