G5x2 guys where do you peak/shift?
Old 07-22-2003, 07:50 PM
BigPlanTransAm's Avatar
Default G5x2 guys where do you peak/shift?
just wondering if this is an ultra high revving cam like it seems. also i cant seem to find any dyno graphs so if anyone has some i'd love to see em
Old 07-23-2003, 03:18 AM
BurnOut's Avatar
Default Re: G5x2 guys where do you peak/shift?
Cam typically peaks @6400, and most folks seem to be shifting @6500.
Considering its size, it's not really that high-revving of a cam.
Old 07-23-2003, 06:33 AM
CamM's Avatar
I have my shift light set at 6500rpm as BurnOut mentioned.
Dyno sheet:
http://web.ics.purdue.edu/~lgigliot/cam/447dyno.jpg
Old 07-23-2003, 07:52 AM
MOBE's Avatar
Same here. Shift light @ 6500, and rev limiter @ 6800.
Old 07-23-2003, 08:54 AM
ws6kid's Avatar
my rev limiter is set @7000....But my shift light will be set at @6500...Like they said it peaks at 6500..
Old 07-23-2003, 09:21 AM
Ramair346's Avatar
Same here, rev limiter is set at 6800 and shiftlight comes on at 6500.
Old 07-23-2003, 10:45 AM
7 Second Club
Phil99vette's Avatar
Looking at that 447rwhp dyno graph you need to be shifting higher than 6500rpm. Have you tried shifting at 7k? I imagine you would pick up a MPH or 2 and lose some ET.
Phillip
Old 07-23-2003, 11:35 AM
Chicago Z06's Avatar
mine is set at 7K rev limit and i shift 68-6900 NA and on spray. in a few weeks i am going to try short shifting at 64-6500 just to see the effects on bottle and NA.. NA i am seeing 120-121 traps... thought i would see a few more mph. but i am not speed shifting so that is affecting it.. but i am seeing 135.xx traps on spray..
Wes
Old 07-23-2003, 11:56 AM
TireFryer30th's Avatar
Damn guys!!
Nice #'s!!
Old 07-23-2003, 01:42 PM
CamM's Avatar
Phillip
You are right...when I shifted around 6700-6800 rpms (close to the rev limiter of 6900 rpm) my MPH in the 1/8 was about 1 MPH higher. I didn't notice much difference in ET.
Old 07-23-2003, 02:17 PM
wow, i like what i'm hearing and that dyno graph looks awesome.
CamM, did you have any problems with PTV clearance on those 5.3 heads?
Old 07-23-2003, 02:57 PM
v8maro's Avatar
uhm, question, how high should I let it rev on stock internals??
-Steve
Old 07-23-2003, 04:45 PM
CamM's Avatar
Thanks!!
My pistons were flycut at LGM motorsports since I'm running 11.2:1 compression with the 5.3L heads milled at aprox .020 (I think).
Old 07-23-2003, 05:57 PM
is lg a sponsor here? i dont see thier banner on the right. i went to lgmotorsports.com but didnt see any mention of the cam on there so i dont know if thats the right site. does anyone have a link? this sounds like an awesome cam but i cant seem to find it
also, has anyone broken parts on the bottom end with this cam yet and would it be a good idea to get some pistons/rods if/when (probably when) the cam goes in?
Old 07-23-2003, 06:58 PM
ne14a6t9's Avatar
camm- so what did it do at the track?, let us know with 60ft mph and d.a. also your wieght. to me it looks like the car made 450 at 6500 and was still climbing. do you have a dyno run going past 6500. for such a big cam it makes great mid range power
Old 07-23-2003, 07:38 PM
Louis's Avatar
That is the right website, just a little slow on the info.
If you would rather call toll free, you could get more info- 1877-LGMOTOR
Old 07-23-2003, 08:00 PM
The Juggernaut's Avatar
I launch at 7k,shift at 6900.
But what do I know?My car is slow.
Old 07-23-2003, 10:02 PM
CHRISPY's Avatar
I would throw in good rod bolts before revving consistently to 7000rpm
From the look of the graph a 6700 shiftpoint should be ideal.
Old 07-23-2003, 10:11 PM
I8AFORD's Avatar
I shift at 6700 also
PS...dont listen to 01Z he is the devil talking..lol....
Old 07-23-2003, 11:25 PM
ne14a6t9's Avatar
01-z if your car is slow, I wish my car was as slow, its good to see you list 60ft and d.a. with your times but what is your race wieght. this g5x2 cam really runs good.
