cam question
Old 03-17-2008, 12:21 AM
Blu99T/A's Avatar
Default cam options with PRC 5.3 heads
I know this question has been asked many times. Yes I used the search option. Anyway here I go. I am looking for a cam to compliment the rest of my mods. I have a set of PRC 5.3 stage 2.5 heads on the shelf, ready to put on. I also have lid, LS6 intake, 160 stat, Pacesetter LT's, TSP 3" duals with x-pipe and bullets dumped, P/P throttle body, and UD pulley, rest of the mods are tranny and suspension. I don't mind spinning it in the 6500rpm range.
I was originally wanting the MS3, but not having the valves set further in the heads, eliminated that possibility. So, now I have been looking at the Torquer 3 and the 231/237cam.
Car is only a daily driver from spring to fall, and sees about 10,000 miles a year. It is a street car that gets driven "spirited" and will see occasional track use. I am looking for opinions (preferably from experience, but welcome all). Numbers, dyno sheets, anything to help me out.
If you need anymore info, please ask.
I will also add that later this year I will be putting in an s60 with 4.11's, I am currently running 3.23 gears. (I was an auto).
Old 03-17-2008, 09:39 AM
Blu99T/A's Avatar
Anybody?
I will also listen to other cam suggestions.
Old 03-17-2008, 08:04 PM
Blu99T/A's Avatar
Anyone?
Old 03-17-2008, 08:11 PM
ABQ99TA's Avatar
I love the Tourquer 3 but I'm no cam guru by any meens. With the 3.23s it will be a pig untill 3500-4k. Good luck It sounds like it is going to kiskass.
Old 03-17-2008, 10:41 PM
Blu99T/A's Avatar
Thank you for your reply.
The rearend will be getting replaced very soon as the pinion bearing is already on its way out as well.
As soon as heads/cam done, rearend will be on order with 4.11's.
I am just looking for the optimal cam for what i have and what to roughly expect.
Old 03-17-2008, 11:36 PM
jsteele90's Avatar
im thinking of running either the torquer 2 or 3. seems to be a good cam a lot of people i talked to recommended it.
Old 03-18-2008, 06:42 AM
teke184's Avatar
the torquers or the F14
Old 03-18-2008, 10:57 PM
Blu99T/A's Avatar
Will the Torquer 3 clear with the PRC 5.3 stage 2.5 heads?
Old 03-19-2008, 02:53 PM
SOMbitch's Avatar
Yes and I believe you can run an .040 gasket with it too.
Old 03-19-2008, 04:14 PM
fastvet's Avatar
Go with a custom grind 230 duration with a 111 or 112 LSA. should handle its own! So, the torquer 3 should put out some power!
Old 03-19-2008, 06:21 PM
Blu99T/A's Avatar
So are u recommending a 230ish custom grind or the torquer 3?
Old 03-19-2008, 07:00 PM
SOMbitch's Avatar
What do you want. Sooner power and more low/mid go lower duration and LSA. Grinding advance into will bring the power down in the band even more. Consider lobe choice as well. Prolly more along the lines I will go. Search for some PredatorZ cams on here.
Old 03-19-2008, 07:13 PM
Blu99T/A's Avatar
Yeah I have spoken to Predator Z and gave me some great feedback with a cam in the low 230's.
Old 03-19-2008, 07:28 PM
cws T/A's Avatar
224/228 @.050 .609''/.588'' 110lsa+0
