got an ms3 cam :)
got an ms3 cam :)
hey guys i got an MS3 cam going in my 2001 ls1 will i need anything else? for every1 who doesnt mind helping me can u put a list of supporting crap that i need?
Since I'm going with this cam too, is the LS2 timing chain good enough or would the double roller timing chain be necessary??
Oh and for Imstock you also need the o-ring, crank bolt, and water pump gasket. I don't think other gaskets are really necessary and can be reused. I might be forgetting something though! Anyone else got feedbackon this??
make sure you get dual valve springs*! Also it is recommended you get lifters. I went the cheap way out and now I have to take it all apart again. I have a collapsed lifter and it would be wise on your part to replace them. so then you would need head gaskets too*
