Autometer oil pressure gauge
Old 03-17-2008, 08:04 PM
sh33p4u's Avatar
Default Autometer oil pressure gauge
Hello -
I've installed an autometer oil pressure gauge and used the sending unit that came with it. I installed the autometer sending unit into the stock location using an adapter. However, when I hook up the gauge(ground, +12v, etc) it reads 100psi, even before I turn on the engine too. I am just testing it out and wondering if any else has had this problem or has a solution. The stock oil pressure gauge was working too, reading about 60 psi before I put this one in.
Thanks for the help,
andy
Old 03-18-2008, 12:32 PM
miller456's Avatar
Dumb question but you never really specified, did you actually start the car or just turn it over?
Old 03-18-2008, 03:43 PM
sh33p4u's Avatar
I did actually start the car. Before I started it, it was at 100psi and after it still read 100psi
