Any reason that one of my Head bolt holes would be...
One of my head bolt hole is filled with oil. Is there any reason for this? Should I worry??? It's on the pass side middle row rear one to be exact.
Scott
Scott
Re: Any reason that one of my Head bolt holes would be...
When you pulled the heads off? The oil comes out of the block when you pull the heads off and it will go everywhere. Thats the only thing I can think of. If the heads are still on than you may have a problem. I don`t have a clue how you would know there was oil in there than.
Nate
Nate
