What is that noise?
Old 03-17-2008, 09:32 PM
MIDNITE Z's Avatar
Default What is that noise?
Any idea what the noise is?
Old 03-17-2008, 09:36 PM
kistlerjm9's Avatar
sounds like an exhaust leak to me
Old 03-18-2008, 04:18 PM
MIDNITE Z's Avatar
Ttttt
Old 03-19-2008, 04:35 PM
Russ K's Avatar
Rod bearing knock.
Russ Kemp
Old 03-19-2008, 05:42 PM
MIDNITE Z's Avatar
Originally Posted by Russ K
Rod bearing knock.
Russ Kemp
Old 03-19-2008, 05:47 PM
slowassta's Avatar
failed rocker, or exhaust leak, bent pushrod
Old 03-19-2008, 05:57 PM
Titanws6's Avatar
Mined just started making the same noise, no exhaust leak, fixed 3 bent push rods-its still there. Consensus was it maybe valve damage
https://ls1tech.com/forums/generation-iii-internal-engine/884645-changed-bent-rods-still-probs.html
Old 03-19-2008, 06:58 PM
MIDNITE Z's Avatar
This doesn't sound good.
Old 03-20-2008, 03:23 AM
DaddySS's Avatar
Sounds more like exhaust leak than anything else.
Old 03-20-2008, 05:43 AM
odarabla's Avatar
Old 03-20-2008, 09:59 AM
lmt0705's Avatar
exhaust leak or rod bearing
Old 03-20-2008, 12:54 PM
67Firebird455's Avatar
Sounds exactly like an exhaust leak to me.
Old 03-20-2008, 01:04 PM
torquejunky's Avatar
Sounds like exhaust leak or valvetrain IMHO, bottom end noises are usually "faster" sounding as the cam turns at half the speed of the crank.
Old 03-20-2008, 01:11 PM
camaro98z28's Avatar
Mike, you have headers right?
Old 03-20-2008, 02:19 PM
MIDNITE Z's Avatar
Jeff, Yes I have headers
Old 03-20-2008, 09:58 PM
mred's Avatar
blown head gasket?
swapping compression between 2 cylinders will sound just like a exhaust leak or piston slap
Old 03-25-2008, 05:05 PM
MIDNITE Z's Avatar
tttttttttt
Old 03-26-2008, 03:41 AM
deputyss's Avatar
im with the exahust leak. keep us updated and let up know
Old 03-26-2008, 08:55 AM
JetBlack98Z's Avatar
Sounds like a Header gasket leak, possibly Collector gasket as well.
Old 03-26-2008, 06:42 PM
Mike, I will be around this weekend after I get my car tuned. If you wanted to stop by I can look at it. Remember when you through a plug? You still have my number right?
