does lower c/r mean slower???
i am going from a ls1 to a lq4.....stock internals....
now will going from 10.5.1 down to 9.5.1 lower hp and make the car slower.....if not
how come everyone says c/r should be higher.....i do plan on running a wet nos kit after break in and tune....is that a good idea or not
stock ls1 cr is 10.2:1 and stock lq4 cr is 9.4:1. i think the lower compression ratio would be made up by the difference in cubic inches - in your comparison. obviously more compression is going to generate more hp (and tq), but if you are getting into the motor during this build, why not do something to bump the compression up?
so high comp higher hp.....then will 9.5.1 take 10%----15% off what i could be making on top line numbers or like 10 20 hp........
i am at my whits end with engine.....dont have the 200.00 for .030 gaskets from cometic
stockers are 63.02 for the set
oh and the reason it;s too late to do it while im in the motor....is because the machine shop just assambeled and balanced the stock lq4 pistons in my build
Here's an excellent article by David Vizard on compression ratio. Vizard knows his stuff. He has a chart in the article that speaks to what your looking for. The power increase isn't a linear factor, but more a diminishing one the higher the compression.
http://www.popularhotrodding.com/tec...ech/index.html
I agree. I'm at 11.5:1 but my engine was built for nitrous. Regardless your engine will do fine on spray, but keep in mind a thinner head gasket is better for nitrous. Less of a chance to blow the head gasket. That's why I also went with cometic .030. Yes they were $180.00 but it's a little bit of insurance that my engine won't have any issues, and of course ARP head studs.
Sell a kidney and buy some cometics! lol
That's a really broad question, but like other said, generally the answer is yes lower compression is less power. (Assuming your CR is not so high that pinging is holding you back)
For example, if say you are running a blower and you cannot run as much advance with 10:1 vs. 9.1....you lower the CR, and you may make more power.
