budget turbo heads
budget turbo heads
alright, i've got some money coming in down the road and i want to start planning now:
-APS TT kit (~8psi tops)
-forged pistons (stock compression)
-some kind of budget head (NEED HELP HERE...want to keep stock compression)
-fully machined block (cleaned up cylinder walls, line hone, blah blah blah) with reconditioned rods and crank
-fast 92/92
-ls6 oil pump and ls2/7 timing set
-after turbo TDs
what kind of heads do you recommend?? i want to keep stock compression and probably the stock cam as well, i may go with a gt2-3 cam from lingenfelter tho. i've searched all around and gone blind on all the head specs from patriot and TEA but nothing really matches up to exactly what i need . i just plain need help here.
-fast 92/92
-after turbo TDs
why fast 90/90 for turbo app? Really isn't necessary. Would be better to get get an ls6 and put the extra 1k or so in headers, intercooler, fuel system or something of the sort. not to mention, i believe that the fast intakes may leak under a lot of boost. Not really a concern until 18 psi, but still, why spend the coin if you can spend it somewhere else.
simply, i plan on taking this motor to 427ci in the not too distant future and i'll need the extra breathing room of a 92/92 then anyway. will some of its potential be wasted on a 346? yes, but i can live with that knowing that i won't have to buy another top shell and TB down the line.
