What Springs??
Old 03-28-2008, 02:01 PM
transam0486's Avatar
Default What Springs??
going to put in a FM14 cam and pacesetter long-tubes, then get the car tuned at speed inc. ...what kind of springs are the best bang for the buck? what are the pros and cons to different brands/ types? ...i'm pretty new to this. what else will i need? ...lifters ect?
Thanks!!
Old 03-28-2008, 02:09 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Id contact Futural since its his cam, you can prob run a new 918 spring with no issues. The more or less standard answer here is a Patriot Dual spring, its good for insurance, but a bitch to get on when doing the spring swap in the car as its tight area and requires some muscles
Old 03-28-2008, 02:18 PM
Tom@SpeedInc's Avatar
PAC 1218 springs are the best beehive for the funds
have a couple sets left
http://www.ls1speed.com/cont.cfm?cid=C0000794
Old 03-29-2008, 05:33 PM
allright that helps. will i need new lifters too?
Old 03-29-2008, 06:26 PM
Last C5's Avatar
+1 for that or the PAC 1518s for up to .650 lift.
Old 03-29-2008, 06:43 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I have run 918's with my 244/248 cam for about 20k. Still have never had an issue. Running stock lifters as well.
Old 03-30-2008, 07:47 PM
so do a lot of guys just run the stock lifters? ...what about the stock push rods
Old 03-30-2008, 07:49 PM
and what's the difference between .600 and .650 lift? thanks
Old 04-01-2008, 03:55 PM
hmmmmm this will be my 1st time working on internals........
Old 04-01-2008, 03:59 PM
Stang's Bane's Avatar
I would pop for a set of good pushrods at the least.
Old 04-03-2008, 02:20 PM
are most aftermarket pushrods the same? ...so i need the cam, springs, and pushrods and that's it?
Old 04-03-2008, 06:09 PM
Evans752's Avatar
I would go ahead and and go with the Comps 921 and they are expensive but for peace of mind I went ahead and sprung for them. Thats what I run with my FM13. I just didnt trust the single 918 spring for that much lift but you might be OK with them. Good Luck with your car.
Old 04-03-2008, 06:26 PM
GMmexican's Avatar
I personally like patriots gold double springs......All the guys in my car club are running aggressive cams and these springs hold up well.
They go for $250 and that includes-the springs, titanium retainers, machined bases, Super 7 Locks, & viton rubber seals
http://www.mphparts.com/mm5/merchant..._Code=FBLS1VLV
Old 04-04-2008, 01:22 AM
Last C5's Avatar
Well, besides the obvious ability to handle an additional .050 or lift and negate the need for a new set if you go to a larger cam, the larger lift PAC beehive spring will give you slightly more seat and open pressure, will be less stressed during it's operating life, and should run slightly cooler. None of these benefits are probably important enough to warrant the extra cost above the 1218's unless your spending a lot of time on the track. Both are very high quality items.
Old 04-04-2008, 09:39 AM
all of this helps a ton, thanks... any more tips/ pointers for my 1st time putting in a cam would be appreciated. ....i've done exhaust and other bolt-ons, and i've rebuilt my t56 but thats pretty much the extent of my experience. thanks!!
