To cam or not to cam? TSP224R VS. TR Cheater
Old 03-29-2008, 07:40 AM
ZMONSTER!'s Avatar
Default To cam or not to cam? TSP224R VS. TR Cheater
Well, I'm down to a couple of head and cam pkgs. They are as follows...
From Texas Speed their PRC stg. 2.5 5.3L heads with 224R camshaft(224/224 .581 114 LSA, or...
Thunder Racing LS1 cheater pkg, AFR 205's and a 214/230 .601/.575 117 LSA camshaft.
My requierments are to be a daily driver with +or- 400rwhp. Also it must pass emissions testing in california and do all this through the stock exhaust manifolds(because Im from cali and it wont pass visual inspection with LT's). A little bit of lope in the exhaust note would be nice.
So which do yall think will get me closest to my goals, also anyone who has run something similar to these please let me know about your set up. Thanks all.
Old 03-29-2008, 08:02 AM
z28ss4me's Avatar
Pretty sure the CheaTR won't pass emissions unless you have a "Friend." If money's not the issue, I'd go AFR and the TR224 vs. the TSP 224R. Basically the same performance, but the TR is easier on your valvetrain and shows just as good number, some would even claim better. Neither will be as good as they can be without long tubes, That's why the CheaTR shines. So, really not a whole lot of big power option to be truly, visual and emissions legal. You'll probably have to compromise some where, for instance the PRC won't technically pass visual either.
Old 03-29-2008, 10:11 AM
ZMONSTER!'s Avatar
Cool,ayone else?
Old 03-29-2008, 10:25 AM
BAD2000TA's Avatar
If you're getting the AFR 205 heads, why not go with the cam that Tony Mamo research, developed, and tested those heads on: the AFR 6016 - 224/228, .581 lift. Do a search on Tony Mamo and you'll find his dyno results and testing. Great street cam, especailly with the high velocity 205 heads. Makes killer mid-range power.
Old 03-29-2008, 10:51 AM
ZMONSTER!'s Avatar
Well because Im not set on the AFR's yet, thats why I posted this, to try to get some more info. If these two pkgs will perform in roughly the same manner then I will probably go with Texas speed, primarily due to cost and you get alot more with their pkg than TR's. Of course you get what you pay for! So I just wanna know if these pkgs are about equal or if one is really better than the other, and how close yall figure Ill get to my goals with either one.
Old 03-29-2008, 01:45 PM
ZMONSTER!'s Avatar
anyone else?
Old 03-29-2008, 02:30 PM
AU N EGL's Avatar
Which ever set of heads you get ask that builder what cam they would recommend to match those particular heads and for your intended use?
Old 03-29-2008, 03:08 PM
Grimes's Avatar
CheaTR will pass emissions.... If you are going with the AFRs, you the 224/228 mamo cam would be a good choice.
Old 03-29-2008, 05:47 PM
kingsey's Avatar
If you have headers get the 224
If you don't get the cheater
Case closed?
Old 03-30-2008, 02:33 PM
SGTZ06's Avatar
Originally Posted by ZMONSTER!
Cool,ayone else?
Go with the TSP package, IMO 10HP isn't worth an extra $1000... I just ordered a TSP's 228R camshaft, I'm not even gonna do heads with mine since I have the LS6 heads. I just can't see spending all that money when I could sell my motor and put it towards like a stroked 402 or 408. Figure if you sell your motor for $2000 and take that $3000 that you will spend after gaskets and fluid thats almost a new motor.
Old 03-30-2008, 07:14 PM
ZMONSTER!'s Avatar
Well there sarge, cant deny that logic!
Quick Reply: To cam or not to cam? TSP224R VS. TR Cheater
