Comp Hi-Tech vs. Magnum Pushrods
Old 03-30-2008, 05:51 PM
ShortChevy's Avatar
Default Comp Hi-Tech vs. Magnum Pushrods
Hey guys and gals, I'm doing a cam swap soon and am wondering the difference between the Magnum and Hi-Tech Pushrods. There both chromoly, hardened, .080 think, and heat treated. Yet Hi-Tech's are about 40 bucks more so what gives. BTW I did a little searching and didn't come up with anything. Also If I'm not changing lifters or rockers I just need the 7.400's right?
Old 03-30-2008, 06:26 PM
allthrotle's Avatar
As long as the cheaper ones are chromemoly with an .080 wall your good so save yourself some money.
Old 03-30-2008, 08:01 PM
1989GTA's Avatar
I think you will find there is a big difference in tensile strength. The Magnum pushrod is the stronger of the two with a higher tensile strength. What this means is you will get somewhat less pushrod deflection.
The valve will open a little further and the valve action will follow the cam better. In other words you do not want the pushrod acting like a polevault. The less deflection the better.
Old 03-30-2008, 08:42 PM
ShortChevy's Avatar
Damn that doesn't make much sense, the Magnum is 40 dollars cheaper...?
Old 03-30-2008, 11:16 PM
1989GTA's Avatar
Your are correct. I edited my post.
Old 03-31-2008, 01:05 AM
Gun5's Avatar
ya mag's are cheaper hi techs are around 120
Quick Reply: Comp Hi-Tech vs. Magnum Pushrods
