Help... Theres Oil Coming Out Of Driver Side Fuel Injectors
Theres Oil Coming Out Of The Drivers Side Fuel Injectors What Do You Thinks Wrong? I Thought It Was The Intake Gasket But Its Not I Swear Its Coming Out Of The Injectors I Never Seen That Before.
Please Help
Please Help
Could be that a bad injector "o"-ring is allowing oil through. Oil could be entering the intake through the PCV system, into the combustion chamber, & then some unburnt oil could be leaking out of the loose or bad injector "o"-ring. Or perhaps oil is leaking by a valve stem seal, bent valve, or gunked up valve seat, & then out the "o"-ring seal of the injector. I'd find out where the oil is coming from & fix from there.
