*idle help* T-Rex/big cam people come in
Old 04-01-2008, 01:10 PM
rmata's Avatar
Default *idle help* T-Rex/big cam people come in
OK, just started on a T-Rex cam install for a buddy's 1997 corvette and I was wondering what's a good drill bit size to start off with for the throttle body to help it idle. We're about halfway through the install so the faster you guys can help the better. The specs of the TRex are 243/249 so similar sized cams let me know. I'd search, but I gotta get back to working on this car. Thanks
Old 04-01-2008, 01:34 PM
GMmexican's Avatar
you dont need to drill the throttle body .....its all in your tune
Ive installed a few big cams, and thankfully we have a good local tuner that can get these cars to idle good
Old 04-01-2008, 01:57 PM
FMX05's Avatar
Yeah the throttle body hole is not the best idea. Its like a last resort to get an untuned car to idle until you get it tuned. Then you would need to replace the blade/fill the hole. I would say start out pretty small if your set on doing it. 1/4 or 5/16 perhaps.
Old 04-01-2008, 02:17 PM
The PAT WS6's Avatar
i have the trex and it drives like stock. all in the tune.
Old 04-01-2008, 03:15 PM
ArklaTexan's Avatar
do not drill, just get a good tune
Old 04-01-2008, 05:30 PM
miami993c297's Avatar
Not necessary to drill the body blade with an ETC...
Christian
Old 04-01-2008, 06:17 PM
neeshSS's Avatar
Like they said, I'd stray from drilling the tb.
Old 04-01-2008, 08:53 PM
kingsey's Avatar
Just get a tune
Old 04-01-2008, 10:25 PM
THEE PEWTER Z™'s Avatar
I never understood why people would do that... THERE IS AN ADJUSTER......Thats what i did to get it to my tuner then had it TUNED
Old 04-01-2008, 10:27 PM
venom ws7's Avatar
TUNE TUNE TUNE Dont drill my brother ran Trex with A4 Without driling the TB and he daily drove it and WITH Stock stall for a while too.
Is the car M6 or A4??
Old 04-01-2008, 11:16 PM
rmata's Avatar
It's an M6. We didn't drill the throttle body. I just thought we might have to because mine was drilled and I run a little bit of a smaller cam, but I couldn't remember what I used.
Old 04-02-2008, 08:15 AM
Firechikn's Avatar
There is a right up in one of the stickys about how the adjust idle air without drilling. I think you open the stop screw, then reset the TPS to zero. I can't remember the steps.
Old 04-02-2008, 09:16 AM
The OP is mentioning it is a Corvette with I guess an Electronic Throttle Control (ETC)...then no screw there.
Christian
Old 04-02-2008, 11:15 AM
Firechikn's Avatar
1997?
Old 04-02-2008, 12:13 PM
1997?
YES, see below:
HomeManufacturersChevrolet1997 Chevrolet Corvette C5Product1997 - 2004
Other improvements include a simplified valve train, unique 'extended sump' oil pan, redesigned pistons, composite intake manifold, revised ignition system and dual-wall stainless steel exhaust manifold.
The LS1 is GM's first gasoline engine with Electronic Throttle Control (ETC), which results in more precise throttle response through all rpm ranges
Christian
Old 04-02-2008, 01:35 PM
Firechikn's Avatar
Learn something new everyday.
