confounded, motor will not turn over!!
Working on a head/cam swap, ready to install, but..................
No timing chain in, no oil pump internals in (doing the .002 shim around oil pump thing), heads off, cam in but rotating freely (XE ~560 lobes)
........And the engine with stock bottom end only appears to rotate 180 degrees. Ends at each half rotation with nice solid thump. Oil pan was lowered to facilitate a oil pump swap. I can see the pistons, of course, and nothing is impeding their movement. We're talking nothing but pistons, conn rods, and crank. Trans is in neutral, but repeats even when clutch is in.
What's up????
The bottom end has not been removed, engine was running perfectly a month ago, before the head porting process was started.
Could the reluctor wheel be moved under the stress of pulling out the crank pulley, or would the thrust bearing prevent this?? I know, the puller works only on the crank.........
What about the oil pan bolts. Is it possible that using the wrong bolts would have created a protruding bolt in the path of the crank rotation??
Is it possible the oil pump pickup tube shifted into the path of rotation??
not too confident I'm not going to feel like a moron after this is solved.
What's up????
PS - better to feel like a moron and fix it now than to feel like a complete idiot and have to tear it apart later...
Oil pan bolts do not go through the block. If the pickup tube is bolted to the pump, it should not interfere with rotation. I can't tell you what it is but, I don't think it is either one of these...
Sunofagun, that thing is dot-to-dot. Whats more, I'm thinking that the motor never got touched from the time that the old cam came out to the new cam went in-- and the dots were aligned when the old one came out!!
Is it 180 outta phase???
First post said no timing chain. I was thinking the only change you made at the crank was the oil pump. If it rotated freely before you mad any changes, I'd start undoing the changes. Pull the chain off and see if it turns if it does, it's the cam. If not pull the pump. If it won't turn after that, it's in the crank, ( or flywheel, etc.), somewhere. Wish I could be more help.
Nice bowtie ink btw...
I agree, I didn't read carefully enough, when you said it's just crank, rods and pistons I thought the cam was out. Hook up the chain with the cam timed correctly and I'll bet it turns over.
i'm thinking of the oil pick up tube hitting or the cam also. as stated,put on the t-chain and then rotate it and if it still contacts look to see if the pickup tube is intefering. if the pickup tube is loose from your oil pump that is what i think it may be.
If I understand this right, the timing chain is off, which means roatating the crank will NOT move the cam, therefore rods are interfering with the cam. Take the cam out, move the crank to TDC, put the cam back in, and then the chain on and try to rotate it. Im am sure it will spin then.
Good point!
Dot to dot. If I was in wit' the savvy internet scene I'd post a vid. I liked the idea of having the stock cam and engine at dot-to-dot before it even came out.
But good point above, I will certainly know if the camshaft is involved if it is sticky with the cam sprocket off and the crank against the "stop".
The bottom bolt for the cam retainer plate can cause interference issues if you put the wrong bolt in. Some of those 10mm bolts are a few threads longer than the others. Remove just the bottom cam retainer bolt and see if it spins over. If so, you got all your bolts mixed up.
With the bolt about 3/8" form all the way in, the engine spins freely. Marc, where do I send the check??
As a follow-up, what is the interference there? Counterweight, or rod?
I've been snickering at all the difficulties posted about this build-up from other members. With this exception, my car has conformed like melty chocolate. Hiccup, I guess.
