How do I remove fuel line from fuel rails??
Old 04-02-2008, 04:06 PM
Bill Bowling's Avatar
Default How do I remove fuel line from fuel rails??
I am finaaly installing my ported Dart 205cc heads. I am also replacing the injectors. I have the intake off except for the one fuel line that goes to the fuel rails. The write up I have says to just remove the rails from the intake and let it hang. I would like to remove it.
I have the clip off and the rubber boot. Does it take a special tool or what.
Thanks,
Bill
Old 04-02-2008, 04:09 PM
DaddySS's Avatar
Yes, it's a plasic ring that you insert inside the connector and it releases the line - be sure to release the pressure via the shraeder valve first.
Old 04-02-2008, 04:11 PM
King Nothing's Avatar
found at your local autoparts store in a 3 pack for about $10 good luck dude!
Old 04-02-2008, 04:32 PM
Is there anything else I can use?
Bill
Old 04-02-2008, 04:36 PM
lastcall190's Avatar
Well maybe if you get a socket that fits around, but inside the sleeve, you can saw it into two semi circles, and jam it in there until you feel a click then pull the line out. That just sounds wrong...
I would just buy the fuel line tool, almost any parts store should have them.
-J
Old 04-02-2008, 04:47 PM
67rsss's Avatar
Go buy the disconnect tools, they are cheap (usually $9.99 for a set of 5 or 7 depending on store) and they are very handy to have for a lot of cars.
Old 04-02-2008, 04:55 PM
Thanks everyone. I am going to go get a tool after supper.
Bill
Old 04-02-2008, 05:52 PM
Just a FYI they do sell them by size. The size you need is 5/16" Angled Fuel Line Disconnect. It was $3+ each.
Now to get those heads off.
Bill
Old 04-02-2008, 06:03 PM
Fratsit's Avatar
Hey Bill....
You ever get those home made flycutting tools?
Old 04-02-2008, 07:23 PM
Originally Posted by Fratsit
Hey Bill....
I never did get them. I PM'd the person more than once. No answer.
Bill
Old 04-03-2008, 02:35 PM
Fratsit's Avatar
Too bad....
I was curious as to how they worked out. I noticed in the past few months alot of questions had been popping up as to which tools worked the best, ect...ect...
R/
Frat
Old 04-03-2008, 02:50 PM
1320 killer's Avatar
you can pick up the fuel line remover tool at your local parts store. Ceap ones are under $10 but they usually break after a few uses. i bought a set of snap on ones and that are holding up pretty good.
Old 04-03-2008, 06:47 PM
I picked one up at O'Relly's for $3.99. It worked great.
Bill
Quick Reply: How do I remove fuel line from fuel rails??
