What to use to clean carbon off pistons??
I used a 3m plastic abrasive wheel from the boby work section of AutoZone. It was the brown colored one, I made sure it wouldn't cut into the pistons first. I would recomend masking off all the coolant pasages and lifter tray areas first.
Internet Mechanic
Wd-40 and a red scotch brite pad.
The some brake clean and a rag should finish her good.
I do not like anything stringent like brake clean or laquer thinner to take off build up with an abrasive pad becuase it could scratch. I worry about this more with cyl heads but I like to make sure its the same that when I left it.
