valve springs
valve springs
ok i will be installing a ls6 cam on mycar the cam is the 2002 zo6 and the springs are also 2002 ls6 springs can i use this springs on my 99 transam heads the springs are installed on my buddies 243 heads can i just removed them and put them on mine or it woudnt fit
May I ask why you only want to put in an ls6 cam if you are going through all the effort for a cam swap? Also yes the will transfer over you will just need a spring tool which can be bought from a member on here for a great price if you dont have one already. Do a search on tims tool and you should find it, if u cant let me know and ill get u a link.
>>LS6 2002 Z06, 204/218 Duration @ 0.050
I assume you're going small on the cam so you will still pass the smog test in CA. I read that the TR 224 114lsa will pass in CA.
Here is a note from SDPC on the Z06 cam:
"New for the 2002 Corvette, the 405hp camshaft for the LS6 engine option. Please note that this cam has approximately a 0.050" smaller base circle than a stock LS1 camshaft. This smaller base circle will require longer pushrods for applications with stock length valves and no milling for the head surface. It is imperative that you check your pushrod length when purchasing this cam. The 2002 Z06 cylinder heads use a longer valve to make-up this difference!"
LS2 head is exactly like a LS6 head but with SS valves 2.00/1.55 and uses LS2/LS6 springs.
Those are good till .580 lifts easy
You had talked about eventually going with a bigger cam. Have you decided to do that yet? Lee and I are running special. Hit me up when you are ready.
Also have not seen you out in some time, you going to come out tonight?
