Crank to Flywheel dowel pin
I have a 98 LS1 outof a Camaro that and I'm missing the crank dowel pin. Is it just a roll pin or a hardend solid pin? Any body in San Diego have on they want to get rid of?
Warning: Bad Trader
you really dont need it just put the 5 bolts on and the flywheel will line up its not goin to go anywhere cause you have to use a aligning tool to line the clutch up so its not goin to go anywhere you dont need it but if you want one its a solid pin
