Ls2 intake manifold
Old 04-05-2008, 11:00 PM
uLs1a's Avatar
Default Ls2 intake manifold
Would an LS2 intake manifold work on a LS1 with the stock LS1 throttle body? Would there be a power difference between the two?
Old 04-05-2008, 11:12 PM
john.s's Avatar
throttle bodies are different i believe. just get an LS6 manifold. direct swap for you LS1 and flow better too i believe
anyone chime in please if i am wrong
Old 04-05-2008, 11:19 PM
uLs1a's Avatar
Yeah I just did a search on it. I think I will stick with an Ls6
Old 04-05-2008, 11:21 PM
THEE PEWTER Z™'s Avatar
An ls2 intake manifold is great if you have it worked..ONLY if it is worked. From all the dyno comparisons ive seen a ls6 will outflow any stock ls2 you put it up against.A ported ls2 although i have seen flow numbers dead on and also higher then an out of the box fast 90. The money you could save by having a ls2 ported will save you maybe 1-200 dollars over a fast.
Old 04-05-2008, 11:23 PM
uLs1a's Avatar
What do you mean by worked? Ported?
Old 04-05-2008, 11:37 PM
john.s's Avatar
yup
but just cheaper and easier to do the LS6 swap
Old 04-05-2008, 11:53 PM
408z28's Avatar
DUDE...dont run a ls2. Been there done that. Besides, if you dont know if you can run a
ls1 throttle body or not on a ls2 intake that screams " im clueless", and you dont need to try it. By the time you buy injector adapters, throttle cable adapters, a 90mm tb, and different fuel rails to make that piece of **** work, you'll have $700 in it, and still make less rwhp than a ls1 intake! ASK ME HOW I KNOW!!! Stupidest thing Ive done (for an intake)
Quick Reply: Ls2 intake manifold
