5.7 or 6.0 Head Gasket for Dart 225 and LS1 Bottom End?
I have a 2001 TA 5.7 std. bore that I'm getting ready to install the Dart 225 heads on and I'm not sure which head gasket to use. Should I use the 6.0 or the 02 5.7 head gaskets? If anyone has this same setup please let me know which head gaskets you used. Thanks for the help.
I installed Dart 225's in December and used the Fel-Pro 1161. I've had no issues to date with them.
Either will work great as long as the deck is properly prepared.
The stock Dart chamber is 3.970" wide, so you will need at least 4.040 gasket bore diameter. Dart recommends either the stock 6.0L GM MLS (.052",4.039 bore) or Fel-Pro 1161 (.053", 4.100 bore).
The 5 layer is the newest version and is alittle thicker but I am not sure how much..
Part # 12589227
This is a .051 and I believe its 4.02 bore and its 3 layer and can be used with Darts but some say its .053 and its 4.039 so who knows for sure
The point is u can run this gasket with Darts...
Part # 12589227
Bad results. My PTV clearance on the intake is tight but squeaks by at .080, but the exhaust side will only go .090. I'm using my old gasket that came on the car to measure with and it is a graphite gasket for a 2001 car. I will be going back with the 12589227 6.0 gaskets I was hoping they were thicker than the graphite gaskets but I'm fraid they are not.
Aaron, are you running the Dart 225's on your car and if so did you have to fly cut the pistons? If not what cam are you running?
If any of you know who rents the tool to fly cut please let me know.
Thanks in advance...
