Does a scratch in the combustion chamber ruin the head?
Old 04-08-2008, 03:26 AM
CashDudeHomie's Avatar
Default Does a scratch in the combustion chamber ruin the head?
Can this be smoothed out and reused? Or will the scratched area still cause a hot-spot in the chamber?
Old 04-08-2008, 03:51 AM
erikshockey's Avatar
take it to a machine shop let them look at it. good excuse to get some ported heads........
but it does look like it could be smoothed out....
Old 04-08-2008, 10:52 AM
Xtnct00WS6's Avatar
Yes, you can smooth that out and you'll be fine. Don't leave it as is though, becaues it would create a hot spot. You could smooth it out yourself if you have a dremel.
Old 04-08-2008, 11:06 AM
9000th01ss's Avatar
How did that get there?
If it broke a ring or piston you might need a machine shop to check the valve seats too, for any particles that might have got between the valve and seat and ruined the smooth surface.
Old 04-08-2008, 11:17 AM
Grimes's Avatar
I agree, smooth with a dremel, and try to remove as little as possible.
Quick Reply: Does a scratch in the combustion chamber ruin the head?
