Head gaskets
Old 04-15-2008, 09:26 PM
ls1slow11's Avatar
Default Head gaskets
Whats the diff between the 02 MLS gasket and the 98-01 graphite gasket my car is a 99 so which one should i get which one is better im doin AFR heads and cam
Old 04-15-2008, 09:32 PM
MrElectric03's Avatar
I think you can use either,or maybe there is a notch in one I remember something about that. IMO the MLS(Multi-layered steel) would be a better choice, but if you are going to put the money into AFRs why not use Cometics and get a higher compression ratio out of it?
Old 04-15-2008, 09:56 PM
ls1slow11's Avatar
got to worry about PTVC or would
Old 04-16-2008, 04:59 PM
ls1slow11's Avatar
any body else what you guys go with
Old 04-16-2008, 05:09 PM
Bill Bowling's Avatar
What are your cam spec?
Bill
Old 04-16-2008, 05:12 PM
BIG_MIKE2005's Avatar
You really need to know what thickness of gasket you need. Are you milling the heads?? If so how much?? What are the cam specs??
I run a 224/.581 cam w/5.3 heads milled .018" on top of the cheapo(17.99 @ Autozone) FelPro stock LS1 replacement gaskets sprayed with copper. Been on there almost 7 months & not a single issue.
Old 04-16-2008, 05:19 PM
ls1slow11's Avatar
232/238 .612/.607 111 LSA + 2 advance xfi lobes AFR heads milled to 62cc so those felpro ones work good
Old 04-16-2008, 05:21 PM
I haven't had a single issue. Just sprayed them with the copper spray, put them on the block & set the heads down on them. Then bolted them down exactly to a "T" per the torque specs.
Block cleaning is where alot of people mess up. Also following the proper torque specs & procedure. These work fine for me, but my cam has far less lift also.
I would think they would work fine for you also though since they are a little thicker than .040" compressed.
Old 04-17-2008, 09:07 AM
ls1slow11's Avatar
So can the MLS gasket be used on a 99 LS1 because at ws6store they advertise it as only 2002 just making sure i can use it on my 99
Old 04-17-2008, 12:55 PM
QuickSilver's Avatar
I have the MLS gaskets on my 99. The only problems were they didnt seal to some of the early heads with the notch in the middle.
THe MLS gaskets held a 200 shot the piston let go before the gasket.
Josh
Old 04-17-2008, 06:31 PM
ls1slow11's Avatar
Will im goin with AFR 205 so i shouldent have a problem then right
Old 04-17-2008, 06:33 PM
you should be fine with the AFR's and the MLS
