slight hesitation at part throttle at low to mid rpm
i did a cam install two weeks ago and everything went pretty smoothly. Two days after i got it done or so the ignition relay took a **** and it wouldnt start. It had no injector pulse and no spark. Now the car appears to stumble when you hit the gas at a low rpm and then climb like it should. I didnt really wanna look under the hood cause if it being hot since ive been driving it all afternoon. Could it maybe be a burnt up plug wire? bad plug? The car is NOT tuned yet...
well whats weird is i didnt notice thsi until yesterday and its been in the car for 2 weeks....i wouldnt doubt the tuning thing though. the computer seems like its constantly freaking out
I don't believe in coincidence so I would strat by checking all of your wiring, something made that relay blow. Check your hoses, grounds, etc. When you say the computer is "freaking out" - what exactly is happening?
the computer will try to compensate for new engine parameters for a few hundred miles but because it still thinks its running stock hardware it will not be able to adapt to your new cam.
its the tune.
its the tune.
