Anybody seen these? Comp Cams Rockers
I did't realize Comp made rockers for the LS1...
GM LS1 Comp Cams Shaft Mount Rockers
http://cgi.ebay.com/ebaymotors/ws/eB...ADME:B:LC:MT:1
Re: Anybody seen these? Comp Cams Rockers
I have their new catalog and they show 4 kits available for LS1. 1.75 and 1.85 ratio rockers. Both each with either a 5/16" guide plate or 3/8" plate.
They must have two size threads on each end of the studs as they are advertising a 3/8" stud. Our rockers threads are 8mm x 1.25 thread.
They say they are bolt on and fit under factory valve covers.
If anybody want the part numbers email me.
Comp also has the Pro Mag pedestal mount type which use guide plates for the pushrods instead of being shaft mounted. They come in either 1.7 or 1.85 ratio for 5/16 or 3/8 pushrods. They cost about $400.00 less. They are high quality are easy to install. I'm sure the shaft mounted type are even easier to install since from the picture it appears that all 8 rockers are mounted on a common shaft meaning you install all 8 of them at a time. What could be easier than that? Just set the preload and your done. Some other shaft mounts are ganged in pairs whereas the Pro Mags must be individually mounted
