pvc question
Old 04-20-2008, 02:20 PM
92slowmaro's Avatar
Default pvc question
i have a torque v3 cam from tsp (231/234 .643"/.598" 111 LSA)
im going to be running some ls6 heads that have been milled .020-.030 think there will be any need to flycutt? ill be checking it anyways while i have everything apart.
what do you think?
Old 04-20-2008, 02:47 PM
LS1Z28_98's Avatar
Well I would be making arrangements to flycut with that cam anyway, let alone the milled heads. Better to do it now than breaking stuff and then doing it later.
Old 04-20-2008, 02:53 PM
92slowmaro's Avatar
ive done flycutting before for other people. but im just seeing if ill have to with my personal setup. i have all the tools
Old 04-20-2008, 04:41 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
It will be really pretty tight. We build our heads with custom valve heights to give extra clearance for additional decking. Im just not sure if a standard ls6 can work with that much decking.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
