p0101 code ???
p0101 code ???
I got P0101 code: maf or vaf a ckt range/perf.
anyone had this code ? Did it fix the problem by replacing the maf sensor ?
My car only has 22,000 miles seems premature for the maf to go out.
I cleaned the maf sensor twice with the maf sensor clear and that didn't solve the problem. I will check the fuse & check the wiring .
ok I checked the owner's manual on the fuse box . I can't find any fuse related to maf sensor fuse on the fuse box located on rt apron & below lt side dash. Where is this maf sensor located ? I checked the wiring behind the male connector it appears fine, I didn't unwrap the wiring electrical tape further back from connector & check it because there is no reason to. any replies ? 36 views and 1 reply, come on .
OK, thanks for that info. I found the fuse it says engine sensor its 15 blue amp fuse & its ok. Now what ? I will be putting in the maf sensor tomorrow if this doesn't solve the problem, maf sensor is not returnable. Any ideas what other sensors can set of this code besides the maf sensor anyone????
