buying a motor built by someone else
not sure where to put this mods move it if ill get beter response somewhere else...
never had a built motor...or built one...done plenty stock motors myself and thats always what i ran...dont have much experience with built ones though...ive talked to this guy and hes been nice and answered all my questions...it seems to be in the ballpark of what i wanted...and looks like it will work with my setup fine...hes shown me recipts...and boxes...part numbers ect...the motors already together (shortblock wise) no cam or covers...built by a shop local to him....
anything i should ask or know when i go to pick it up? guys been on ls1tech for a while but has a very small amount of posts....have a +2 trader rating...gave me his number very quickly and said call if i wanted to talk about it...
This may get moved.
I would tear it down and check everything and have a shop you trust put it back together when you get the rest of the parts.
I would allways tear them down unless the motor cam from someone I am friends with.
I would turn the engine over by hand and make sure it turns freely.
I would hate for something not to be torqued right and trash the motor just because you did not check it.
dont forget to plastiguage the rods, and main bearings, also if you assemble it from the new shortblock dont forget the front oil gallery plug, and the rear barbell restrictor is installed. ohh and the main bolts if stock are TTY so you will need a new bolt kit. (get a good torque wrench and a torque angle meter). check the ring gaps while its apart, would be nice to know what material rings it has, pistons rods crank etc., molly rings are stronger, putting it back together make sure to check the splash shield for rod clearance, shim it down if needed (stroker cranks), if you want to do it right, check the mains to be true, send the crank rods and pistons to have them ballanced, use clevite coated main and rod bearings, they are the best out there. thats all i can think of right now.
Take your time. be sure to do everything correct. before you crank, you have to prelube the engine with the oil filter adapter pump. you can also verify getting pressure readings off the ipc oil pressure guage while priming if you can pump the thing fast enough.
At the very least I would have the seller pull a couple of rod and mains for a quick plasitigage check, before shelling out your hard earned cash. I see no reason if someone wants to sell an engine to show the buyer a couple of basic clearances are within spec.
Personally, I would check all clearances before firing it up.
