AIR removal/blocks and intake manifold??
Ok, my headers block off plates should be coming soon. Im going to take off the emissions rubber piping and that assembly from the back driverside of the car.
Can someone direct me to doing this and taking into consideration pluggin necessary devices up and vacuum as well.
There must be someone out who has done this already or doing it.
I hope my description is clear. thanks
Your kidding have you searched this topic? its been discussed with pictures for help numerous times. There isnt much to it, just unbolt the air tubes and mount the block off plates back on. You can get some 5/16 rubber plugs from any auto parts store and plug ur valve cover, and i found that a pcv valve fits perfect into the hole in the driver side valve cover to plug it. Then remove them ugly rubber hoses and get under the car and take the air pump off.
