Autometer Oil psi gauge not working
i just got my car back from the shop about 2 weeks ago and my autometer oil psi gauge stopped working.. but the stock one in the dash still works. so i checked the connections thinking that maybe it fell off the sender but it didnt so i pulled the gauge and did the same on the back and they are all fine.. and if it was the ground my water temp wouldnt work either because they are grounded together. do you think it is possible the assembly lube would clog or mess up the sender in anyway because it had break in oil in it when it stopped working? thanks for the help
