Quick preload/pushrod length question
I've searched and searched tonite and I still have a question. I got a combo of a heads, cam, pushrods that were slightly used and installed them. I got the idea to check pushrod length/preload and here's what I found. I get apx 2 turns of preload with caddy lifters which should be good. While doing this I notice both valves start to open slightly. Is this normal? The engine has been apart since about Oct. The cylinder is at TDC also.
the heads are ETP 225 w/their rocker stand, stock rockers, 8.2 pushrods and a comp cam of some sorts. I found an old post from 06 where the member had the same setup, same results....but there were no replies. here's the post
https://ls1tech.com/forums/showthrea...hlight=preload
