Packing the Oil Pump?
Old 05-01-2008, 07:26 AM
PRO AUTO's Avatar
Default Packing the Oil Pump?
Does any one pack the oil pump with vasoline or a type of grease when reinstalling to help prime the pump on initial start up? I use to mess with old Buicks and to prime the pump you would pack it with vasoline to make it pick up the oil.
Thanks for your help.
Old 05-01-2008, 07:28 AM
Deeavi's Avatar
Not necessary! Just make sure you have the correct new o-ring on the pickup tube
Old 05-01-2008, 08:47 AM
1CAMWNDR's Avatar
I agree. Just put it in and crank the engine over a couple times without the coil packs hooked up. Then connect them and fire away!
Old 05-01-2008, 09:51 AM
LS1Z28_98's Avatar
Agreed,
I asked the same question not long ago. I did what the rest said, crank it over without the packs attached. I did this and it took maybe a minutes worth of cranking and I had over 40psi just from turning it over.
Old 05-01-2008, 03:55 PM
voda1's Avatar
Would it be better to disable the injectors?
Old 05-01-2008, 04:10 PM
bczee's Avatar
I would disconnect both the Fuel pump and coils.. but also filled my pump with STP, not as heavy as vasoline or a type of grease, but it down help cut down the time it take to prime the system.
I know that the rest has stated Not Needed.. but it can't hurt and does help seal the rotors in the pump and gets the pump sucking quicker and primes the rest of the engine system.
Old 05-01-2008, 07:43 PM
HEMIETR's Avatar
I would make sure the pump is centered on the crank also
Old 05-01-2008, 08:44 PM
TheCarKid's Avatar
disconnect the ignition coils and while you're cranking the engine, put the pedal to the floor. the ecu will not fire any injectors as flooring the pedal while cranking is a signal to clear out the cylinders in case they're flooded.
Old 05-01-2008, 08:47 PM
PRO AUTO's Avatar
Great information from all. Now if you have time I have bigger fish to fry with my new post of PTV issues. Please help if you can. Thanks.
Old 05-01-2008, 09:32 PM
SOMbitch's Avatar
Cool info. Never heard this!!
Old 05-01-2008, 09:48 PM
shoemike's Avatar
dip the gears in oil before you install them in the pump.
Old 05-02-2008, 12:00 AM
bww3588's Avatar
called "clear flood mode"
Quick Reply: Packing the Oil Pump?
