Would bad spark plugs cause this?
When I'm cruising down the highway and step into the accelerator a little, I can feel the car stumble a little bit/miss/whatever until I step into it a bit more and accelerate much more rapidly.
How can I check the EGR?
a vaccuum leak such as you described can cause this symptom. Also, a stuck or sticking EGR can allow too much exhaust gas into the intake causing the car to run lean which will again cause this problem.
Shane
Shane
