air pump replacement?
Old 05-03-2008, 11:50 PM
TraviZ's Avatar
Default air pump replacement?
How easy/hard is it to replace the air pump? Mine needs to be replaced for smog, as well as the solenoid hoses, filter, and check valves. This is what the dealership told me.
I see I can get most this stuff off ebay for a much better price then the dealer, and its all new!
just curious on the work involved. could I do it at home in a day? I dont even know where the thing is located, its not belt driven like the POS on my IROC was. ( I ditched that thing long time ago)
Old 05-04-2008, 12:29 AM
DaveX's Avatar
It's very easy to get to. It's' in front of the driver's side wheel well. You can get to it from underneath.
Old 05-06-2008, 05:37 PM
TraviZ's Avatar
Thanks, Found it. Didnt know what I was looking for at first.
Next question, what are the interchangable years? mine is a 98 z28.
will a smog / air pump from a 00-02 work as well?
Old 05-06-2008, 05:41 PM
FrankSS's Avatar
unless you live in cali then i would ditch it... maybe the stealership tryin to get some money off of u
Old 05-06-2008, 06:22 PM
TraviZ's Avatar
I do live in cali and smog is due this month
Old 05-06-2008, 09:45 PM
mvvette97's Avatar
If ya need a pump I happen to have one I took off my trans am. If interested I can see if I can find it tomarrow
Old 05-06-2008, 10:22 PM
TraviZ's Avatar
is it a 98-99 TA? i keep seeing different part numbers for the 98-99 and 00-02 models.
I am interested however, let me know
Old 05-06-2008, 10:36 PM
mvvette97's Avatar
mine is a 2000. Yea i have no idea on the part numbers
Old 05-07-2008, 07:58 AM
dbuie's Avatar
Why can't he just keep all hardware intact but just delete the AIR system from the computer. Since it only works while the car is first started I would assume that by the time he got to the inspection station the AIR system wouldn't even be running anyway because the car is at normal operating temp.
Old 05-07-2008, 08:10 AM
ssgunny's Avatar
I agree unless the plumbing of the AIR system is something they look for during the inspection.
Old 05-07-2008, 08:28 AM
dbuie's Avatar
All of my plumbing is 100% intact and I bet it would pass their visual with no problem. I was just curious about how stringent CA is.
Old 05-07-2008, 08:56 AM
GuitsBoy's Avatar
I agree to tune it out. Wont turn a code. The air pump isnt used during driving while youre on teh rollers getting smogged anyway.
Old 05-07-2008, 09:33 AM
TraviZ's Avatar
Its frozen, they DO check, and my engine light comes on because of it.
Old 05-07-2008, 11:27 AM
dbuie's Avatar
Not to be argumentative but so did mine until I had it programmed out. No more CEL and all items are still on the car. If they do check then how do they check for this? My *** was tight the first time I took my car in for inspection after my computer was "tweaked" but it passed with flying colors, just as the computer tweaking company told me it would do.
Old 05-07-2008, 11:46 AM
GuitsBoy's Avatar
Yeah, once you get it tuned out, you wont get a SES light, the computer will read that it passed its self diagnostic. And the air pump only runs at start up, not once teh car is warmed up. So it is not going to affect your smog numbers on the rollers.
Old 05-07-2008, 12:47 PM
triggerjerk's Avatar
I had all my air pump codes blocked/turned off with ls1edit.
It passed an obddii plug in test after starting the car and letting it warm up for a few minutes and then driving it to the station. The car sat for a week before that. I was afraid it might not "be ready" per the codes but it passed.
It is still working for now but it makes strange noises every now and then so i decided to just program it out.
Quick Reply: air pump replacement?
