Cam Install
Old 05-04-2008, 05:24 PM
LS1Birdy's Avatar
Default Cam Install
I have everything taken apart, down to the step of taking out the cam, and i'm doing the step of taking a 5/16 metal dowel into the holes for the lifters, now what i have noticed is that when the dowels are in completely i can still put my pen magnet in the pushrod hole and push the lifter onto the cam, because as i turn the cam the magnet is moving...Is there something im not doing correctly or what?
Old 05-04-2008, 05:46 PM
seminolefamz28's Avatar
as long as you have the rods all the way to the back of the block you are good to go all you gotta do is pull out the cam
Old 05-04-2008, 10:02 PM
mrhzk35404's Avatar
The lifters will still move a little bit. I used the wooden rods.
Old 05-05-2008, 12:33 AM
snake charmer's Avatar
+1 an easy way to see it is all the way back is take a marker and lay the dowel next to the cam and mark it wher it ends . this way you can see when you put the dowel in if it has went the length of cam you are trying to swap .
Old 05-05-2008, 12:35 AM
droptopT/A's Avatar
yup thats what i did and i double checked with the pen magnets and the lifters still moved a bit but they wont fall aslong if the dowels are al the way in
Old 05-05-2008, 05:22 AM
Restricted User
socmguy's Avatar
you're good, pull that sucker out
Old 05-05-2008, 06:27 PM
LS1Birdy's Avatar
Alright thanks, that makes me feel better than...just wanted to make sure that one of those lifters wouldn't fall down
Old 05-05-2008, 07:42 PM
Fb0dy0nly's Avatar
I was worried too when it came time for that the first time but I realized that I didnt even need them as when I put the new pushrods in, I pushed all the lifters back onto the new camshaft, which is good but I would never pull out a cam witout them, just too risky.
Old 05-05-2008, 08:12 PM
Bill Bowling's Avatar
Have you got that mother changed yet?
Hope everything goods OK.
Bill
