Having some major mechanical problems that can't seem to be solved!
Copied and pasted from another forum.
http://forums.corvetteforum.com/show....php?t=2009265
There is my original thread to review. As of now the car is still at the shop, wiring schematics have been went through, plugs checked, sensors checked to my knowledge and still no cause has been established and my damn car still won't start.
Any guru's have any possible ideas? Help please!!!
has a comparable ecu been installed ive seen some wierd stuff being a drivability tech for gm, in corevettes and xlrs they have a problem with static electricity frying pcms and doing something similar to what you got or a loose ground
to accurately diagnose it you will need more than just the codes you need to pull the data values and try and find someone that can get on gm dealerworld service information and get the flowcharts for the codes which will steer you in the right direction step by step i worked at an independent for a while that had both of these but for the most part thats why the dealers make the big bucks because they got this stuff
