What octane gas for 11.60 scr and 8.80 dcr?
Old 05-09-2008, 02:49 PM
Stroker2112's Avatar
Default What octane gas for 11.60 scr and 8.80 dcr?
Anybody running the above scr/dcr on 91 octane?....
Old 05-09-2008, 06:28 PM
DaveX's Avatar
Mine is 11.3 and 8.7. Premium here is 92 - 93 octane and I'm not seeing any KR. You might be ok.
Old 05-09-2008, 08:03 PM
allngn_c5's Avatar
Can you tell us about your setup and so we can see what h/c you used to get those compression numbers. 93 octane should be fine, as long as the tune is good.
Old 05-10-2008, 10:07 AM
Allngn c5,
The head/cam combo - ported 243s (62cc) with a 236/242, .595/.598 lift, 112lsa,108icl cam... with a .041 quench...
Old 05-10-2008, 10:09 AM
92 octane is the highest around here...
Old 05-10-2008, 12:44 PM
allngn_c5's Avatar
I say you would be ok using 92 octane. If you starting getting KNOCK then you may have to pull a couple degrees of timing from your tune.
