How many guys deep in the 11's or 10's have ASP pulley?
Old 08-07-2003, 09:05 PM
mike#9's Avatar
Default How many guys deep in the 11's or 10's have ASP pulley?
Just what it says.... is it a mod that is a must to do. How many of you guys that are serious/not so serious drag racers that make over 430 rwhp and run well into the 11's and/or run 10's have them?
The reason why I ask is because I have heard mixed reviews, and I ordered one today almost out of impusle because of them never being in stock.
Did I make a bad decision. I have a 10" JL sub and 300 watt amp.... with factory Monsoon. Will I see any problems?
I only got the crank pulley.
Old 08-07-2003, 09:53 PM
felton316's Avatar
Default Re: How many guys deep in the 11's or 10's have ASP pulley?
Call ASP for their alternator overdrive pulley. This will allow you to keep the bumpin stereo and still underdrive all other accesories 25%. most people are seeing a 5-9 hp increase on the dyno with this mod. I haven't got to dyno mine since I put the pulley, so I dont have any personal results yet.
Old 08-07-2003, 10:23 PM
Colonel's Avatar
It's no problem even with a nice system and no overdrive pulley. I've had the ASP pulley on all three of my F-bodys...including the 9 second one. In all three cars I've run a 10" JL sub and 450 watt amp. Like I said, no problem.
Old 08-07-2003, 11:15 PM
Mike K.'s Avatar
most people get the pulley as one of their mods. Don't worry you did not make a mistake. I don't have a system but the car electrically seems no different than stock with the pulley and like felton said you can get an overdrive for the alternator if you have to.
Old 08-07-2003, 11:16 PM
I can shift faster than you.
Jason99T/A's Avatar
I had an ASP pulley on my car for the last 3 years with no issues. Excellent mod!
Jason
Old 08-07-2003, 11:17 PM
Restricted User
CAT3's Avatar
no problems.
Old 08-08-2003, 05:30 AM
Hannibal's Avatar
Excellent mod - feels like car revs faster - good for an easy 7-8 RWHP. No charging issues at all.
Old 08-08-2003, 06:24 AM
verbs's Avatar
I've had mine for about 2 years now and zero probelms. I use the crank and alt pullies, and run a 500 watt amp on top of the 500 watt monsoon system and also use a Odyssey lightweight racing battery
Sounds like a crazy combo, but no problems at all.
Old 08-08-2003, 11:33 AM
mike c.'s Avatar
no probs with my asp pulley. 2yrs and hi-11's with mine.
Old 08-08-2003, 01:51 PM
mike#9's Avatar
Cool... thanks guys!!!
Old 08-08-2003, 05:34 PM
Cal
Cal's Avatar
The only time you would ever have a charging problem would be at idle, but most people that install a pulley also have a cam so they have probably increased the idle speed for the cam.
Old 08-08-2003, 08:18 PM
Ragtop 99's Avatar
The only time you would ever have a charging problem would be at idle...
Yup. Only time I've seen problems is with both pullies on a stock idle speed A4. With just the crank pulley, I never had any issues with a stock idle.
Old 08-08-2003, 10:47 PM
beardWS6's Avatar
I love it, works great for me! I have it on my A4, check Sig!
Old 08-08-2003, 11:49 PM
2000SILVERTA's Avatar
dont listen to the mixed reviews. get one, if you dont like it get rid of it. I'll bet you like it. I love mine.
