found 10 mil socket behind flywheel???
i bought my car 2 years ago and since then have put ls6 stage 2 heads on, ms4 cam, full exhaust ect. anyway i got my car dynoed and only put 356 down to the wheels. my clutch has been acting pretty crappy with the petal sticking to the floor and slipping so i figured it was spent. ive had a new stage 3 clutch for a few months but not having a garage had to wait for better weather to put it in. so i put the car up on jack stands and pulled the tranny and noticed that i was leaking oil pretty bad. ive had a small oil leak in the rear for awhile but didnt want to pull the tranny til i was gonna put in the clutch. i got new rear seals to fix the oil leak. well when i pulled off the flywheel a friggin 10 mil socket fell out from behind it and i noticed the oilpan gasket was chewed up when i pulled the cover with the rear seal in it off. anyways im just wondering why the hell someone would put a socket in there cause from what i can see i dont know how a socket could just fall in there and be behind the flywheel??? seeing as how the oilpan gasket is screwed up i guess im gonna go get one and put it on. also any suggestions of any other maintanance i should do while i have all this apart cause i dont really wanna pull the tranny again for something dumb that i should take care of now. when i find my camera i can post up some pics of the socket and the chewed up gasket if anyone cares to see. thank in advance for any input
what little barbell piece? i didnt see one in there but then again i wasnt looking for one. i have a new slave cylinder that im putting in and im not sure but i think the throwout bearing is on the slave cylinder correct me if im wrong. what do you use to get the pilot bearing out? and should i replace the master cylinder or just do the drill mod cause i was gonna do the drill mod when i did the slave cylinder but wasnt sure if i should replace the master or just drill it.
Yes the throwout bearing is on the slave cylinder. To get the little pilot bearing out you need a mini 3 jaw puller or something similar. Using the wet bread/paper method does NOT work. There is actually a freeze plug behind the pilot being that will actually push into your block before the pilot bearing comes out.
ive seen this. someone was taking off the pan and lost the socket through the two rear bolt hole that are up through the little tunnel between the pan and tranny.
The drill mod is when you remove the clutch master cylinder from the car and pushing out the small roll pin that holds the braided line to it and using a 1/8 drill bit to drill out the restriction in the line from the factory . Go to installuniversity.com for the write up on it .
