Custom Crane Cam RPM Range 236/242/600/609/110lsa ???
Old 05-20-2008, 08:57 AM
NASTYTRANSAM's Avatar
Default Custom Crane Cam RPM Range 236/242/600/609/110lsa ???
Hey guys just looking for some ideas of what you think my power band should be on my car with this cam grind. Im getting mixed feelings on what I should be looking for as far as the cam. I was thinking it should be in the 3600-6500 RPM range peak power. With some decent low end torque. I was told that this would be " over camming " my car and I shouldn't expected it to pull hard above 4000 RPM by the people who tuned my car. Below 4000 RPM I can't keep the tires from blowing off... And I have 315/30/18 BFGoodrich drag radials, then as soon as I hit around 42-4500 ish rpm it lays down and doesn't pull hard anymore. It seems like if I had over cammed my set up I would need to spin it up into the higher rpms to get into my power band. Not run out of power up high. Thanks for any Ideas
Here is a list of mods
Ported LS6 intake
Ported maf sensor
Ported Throttle body
Crane custom grind 236-242-600-609 110lsa
Crane Dual Spring Kit
American Racing 1 3/4 race headers - off road y-pipe
Corsa Catback
Yank 3600 Stall
Fully built 4L60E
Reactor Flexplate
SLP under drive pulley
3.73 gears
Old 05-20-2008, 09:41 AM
Ryan L's Avatar
Post your dyno chart.
Old 05-20-2008, 09:57 AM
Well the car hasn't seen the dyno yet it will this weekend.. My car got "Street Tuned" so far. I will post a dyno graph after this weekend
Old 05-20-2008, 10:21 AM
s346k's Avatar
4500-7000 rpm. who tuned the car?
Old 05-20-2008, 11:00 AM
A LS1Tech sponsor......
Until I know if its in the tune or the cam choice or what is going on thats really not relevant. Im not looking to criticize anyone
Old 05-20-2008, 11:28 AM
5_02ls1's Avatar
over camming an ls1..........................
hahaha that cam is small compared to some ive seen guys run on here....being on a 110
id say your guessed powerband is about right....does the cam have any advance ground in??
Old 05-20-2008, 11:46 AM
JPH
JPH's Avatar
it does, but had to back it up 2* for comfortable ptv issues. 110icl now.
Old 05-20-2008, 11:48 AM
5_02ls1's Avatar
id say its in his tune or maybe in need of some more injector.....
Old 05-20-2008, 12:25 PM
s346k's Avatar
i'd get it on a dyno and see what's going on. that cam should come on like a switch @ about 5,000 rpm. my buddy has that exact same cam in an a4 car with a 4k stall, it runs hard, good choice.
Old 05-20-2008, 12:29 PM
hammertime's Avatar
Since it appears you are still on stock heads, I wouldn't think you should be running out of injector just yet. And while it may not matter much with your 3600 stall, I wouldn't expect much power below the curve with stock compression.
That cam on a 110* ICL isn't closing the intake valve until 48* ABDC. The cam will want to peak over 6500, and the exhaust bias should allow it to pull well to 7000.
Your tuner should be able to tell you what the AFR and timing are in the upper RPM's, that should help steer you to what your car wants. He should also be able to tell you what the injector duty cycle is to give you some idea whether or not the injectors would even be a concern.
Is the same tuner doing your dyno tuning?
Old 05-20-2008, 01:02 PM
Its not getting dyno tuned Im just getting a dyno pass with air/flow ratio cheap.
The tuner said the first time I asked that I had 92 % then said 107 % duty cycle so I have no clue?? I don't want to change injectors unless im sure I need them..
Old 05-20-2008, 01:10 PM
5_02ls1's Avatar
throw a fuel pressure gauge on it.....pump may be layin down or maybe somthin as simple as a clogged fuel filter.....no way its the cam......just a couple simple things you can check...
Old 05-20-2008, 02:40 PM
Prerun4fun13's Avatar
I have an MS3 cam only and i used SVO 30 injectors just in case also if i wanted to upgrade more i wouldn't have to get new ones. I would say your injectors are maxing out.
Old 05-21-2008, 08:44 AM
MNR-0's Avatar
Thats a nice entry level lstreet cam in my book.
I had one very similar and it drove better than my 212-220 and 228-232. Mated to a 3000 stallie it worked exceptionally well on the street. For the strip, it needs a 4000.
A well setup engine, heads, tune and exhaust should see that cam pull 400+rwhp easily.
Old 05-22-2008, 02:44 PM
WOW Pal thanks but I have this cam and am not looking to change it. Im just looking for ideas of what people think it should be power band wise.....
Old 05-22-2008, 03:47 PM
CTS-V LEE's Avatar
I would have to say its the driver...maybe ur right leg is to short...ur probably not pushing the gas pedal all the way down...thats my guess...
Quick Reply: Custom Crane Cam RPM Range 236/242/600/609/110lsa ???
