Quick Question on 1.85 rockers?
Old 08-08-2003, 08:09 PM
firebirdls1us's Avatar
Default Quick Question on 1.85 rockers?
I am going too install new roller rockers and I,m looking at the 1.85's but can I use them with my cam the specs are
224/232 581/593 Or would I be better off with the stock 1.7's? I already have stage 2 heads so springs shouldn't be a issue right?
Old 08-08-2003, 11:09 PM
FDLS6's Avatar
Default Re: Quick Question on 1.85 rockers?
You will not be able to use that cam with 1.85 rockers. The lift would be .632" and .645" Your springs will not handle this(unless you have a VERY unusual stage 2 head spring package).. also, it will put a very heavy load on your rollers, likely causing float, or loss of performance at higher rpms (even if the springs were up to the challenge). You'll have to swap in a milder cam if you want to use 1.85 rockers. I hope this helps.
Bryan
Old 08-09-2003, 06:49 AM
yes well thats kinda what I was thinking also but was just checking for curiousity.
Thanks
Old 08-09-2003, 09:30 AM
2000ws6transam's Avatar
yes stay away from those!! with that agressive of a cam profile somthings going to break!
