i think #7 popped, leak down ? inside
well, i started out on 1,6,8,5 then got to #7 and over 50-60% loss. if i plug up the breather air comes out the intake. slightly bumping the crank back and forth really has no effect.
i went 1,6 turned crank 90 degrees, then 8,5 turned crank 90 degrees then 7. is that the right order?
possible piston, ring damage hurt the intake valve?
damn 8psi !!!!!
damn 8psi !!!!!
