Are coil packs/harnesses side specific?
I pulled my covers,coils,brackets apart to clean them. I left the harnesses plugged into the coils but never noted wich side each coil row came off of. Are the coils/harnesses driver/passenger side specific?
LS1Tech Premium Sponsor
No, they are not specific.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Are the coil pack wire harness's the same for all years on the F-bodys? Im needing both sides for an 01 motor but dont want to buy the incorrect ones.
I searched the part number sticky but found no coil harness part number.
need to know if a 98 coil pack is the same as the rest of the cars.
i would GUESS that the wiring for the 98 cars may be different due to the engine harness is different. i could be wrong.
harness are coil specific. car coil will not interchange with a truck coil. the harness are different between them as well.
